Add Algorithm
Add a new algorithm as follows:
- Algorithm: CM EXPDT-iii.
- Description: Date must be a future date
- Algorithm Type: CM ADHV-iiiJ
- Effective Date: 1/1/2010
- Parameters:
- Sequence: 1, Parameter: blank
- Sequence: 2, Parameter: blank
- Sequence: 3, Parameter: YYYY-MM-DD
- Sequence: 4, Parameter: YYYY/MM/DD
- Sequence: 5, Parameter: MM-DD-YYYY
- Sequence: 6, Parameter: MM/DD/YYYY
- Sequence: 7, Parameter: MM.DD.YYYY
- Sequence: 8, Parameter: 0.001
- Sequence: 9, Parameter: 0
