Jump to main content
Oracle Utilities Application Framework Software Development Kit
Search
Home
User Guide
Cookbook
Plugging in Algorithms
Creating Algorithm Spot Implementation Class
User Guide
Overview
Converted COBOL Programs
Development Environment
Build Server
Tailoring Your Oracle Utilities Application Implementation
JUnit testing
Technical Background
Metadata Overview
Development Process
Cookbook
Hooking into User Exits
Maintaining General-Purpose Maintenance Classes
Maintaining MOs
Maintaining Database Meta-data
Maintaining Java Classes
Maintaining Services
Maintaining Foreign Key References
Maintaining Lookup Tables
Maintaining Navigation Keys
Maintaining Navigation Options
Maintaining User Interfaces
Maintaining Menus
Maintaining Application Security
Maintaining UI Components (Translation)
Review Algorithm Spot Definition
Create Algorithm Component Implementation
Add Algorithm Type
Add Algorithm
Create References to New Algorithm
Maintaining Portals and Zones
Maintaining Background Processes
Creating Javadocs for CM Source Code
Utilities
Developer Guide
Packaging Guide
