Display Usage
To display the usage information, execute the utility without any parameters from the Windows command prompt.
	perl extractCMSource.plx
	 extractCMSource.plx -s sourceDirectory -d destinationDirectory -v Version
	         [ -n subDirectoryName ] [-m CmOwner ]
	    -v Version
	        The Version Number to attach to this release of
	        the Customer Modifications.
	    -s sourceDirectory
	        sourceDirectory is the location to extract from.
	        destinationDirectory is the location in which the extracted files
	        are placed. The program then creates a subdirectory under the
	        destinationDirectory to hold the patch.
	    -n subDirectoryName
	        Subdirectory under "Directory" in which this patch will be placed.
	        If this parameter is not provided, an automatic directory name
	        is generated based on the environment name and date/time.
	    -m CmOwner
	        Used for a Multi-CM jar enhancement, this optional parameter
	        specifies the CM owner that needs to be extracted from the
	        project directory (e.g., "cm01"). If not specified, the script
	        uses the default "cm".
