Extract From Release/Patch Install Package
To extract the source from a release or patch install package, specify the data directory in the install package as the source directory. For example, the following invocation extracts source from a patch install package named CM1.0_1 in the C:\CMInstall directory into C:\CMExtract and marks the extract as version CM1.0_1:
			perl extractCMSource.plx -s C:\CMInstall\CM1.0_1\CMCCB\data
			     -d C:\CMExtract -v CM1.0_1
