External User Exit Templates
Below is the list of all available external template files. They are located under the
\cm_templates
folder of the application root directory.
Note: The flowcharts above illustrate user exits in the Tab Page and List Grid templates only; these are the templates in which most of your customizations will occur.
Accordion: accordionPage.jsp
Graph Panel: graphPanelExit.jsp
List Grid: listGridExit.jsp
Search Data: newSearchDataExit.jsp
Search Page: newSearchPageExit.jsp
Sub Panel: subPanelExit.jsp
Tab Page: tabPageExit.jsp
Tree Page: treePageExit.jsp
