Test default actions on Maintenance Class
In addition, all defaults that are registered for a page maintenance must also be tested. This should be done through separate tester methods for each default, calling the FW support method public PageBody executeDefault(PageBody pageBody, String defaultValue) :
			    public void testDefaultChg() {
			        PageBody input = new PageBody();
			        // TODO populate inputs for default
			        // e.g.
			        input.put(Maintenance.STRUCTURE.FK, "FK CODE");
			        PageBody output = executeDefault(input, Maintenance.DEFAULTS.CHG);
			        // TODO compare the outputs
			        //  e.g.
			        assertEquals("FK Description",
			             output.get(Maintenance.STRUCTURE.FK_DESCR));
Here is an example to test the default on a field under a list.
			 public void testDefaultAlogrithm() {
			        ItemList itemList = input.newItemList
			             (Maintenance.STRUCTURE.list_MRRA.name);
			        ListBody listBody = itemList.newListBody();
			        listBody.put(Maintenance.STRUCTURE.list_MRRA.MRR_ACTN_ALG_CD,
			             "MRRCRESVCCC");
			        PageBody output = executeDefault(input, Maintenance.DEFAULTS.AAD);
			        ItemList outList = output.getList
			        ListBody body = (ListBody) outList.getList().get(0);
			        assertEquals(body.get(Maintenance.STRUCTURE.list_MRRA.MRRA_DESCR),
			             "Create Service Customer Contact");
The input page body should be populated with the expected inputs for the default action, while the output should be compared against the expected output.
