Jump to main content
Oracle Utilities Application Framework Software Development Kit
Search
Home
Developer Guide
Public API
Data Objects
ItemList
List getList()
User Guide
Developer Guide
Overview
Java Annotations
Public API
SQL Return Codes
Standard Business Methods
Business Entity Public Methods
Maintenance Class Public Methods
UI Javascript User Exits
Java User Exits (interceptors) Interfaces and Classes
RequestContext Methods
Data Objects
PageHeader and PageBody Methods
PageHeader
PageBody
ItemList
ListHeader getHeader()
String getName()
List getList()
void setList(List list)
ListHeader
ListBody
CMServiceConfig.xml structure
Application Logs
Java Programming Standards
HQL Programming Standards
SQL Programming Standards
Database Design
System Table Guide
Key Generation
Development Performance Guidelines
Packaging Guide
List getList()
Return the
java.util.List
of ListBody child objects.
