Maintaining Foreign Key References
You need to set up foreign key references if you have characteristics whose valid values are
defined in another table (for example, if you use foreign key reference
characteristic types).
Note: For detailed information about foreign keys, see "Primary and Foreign Keys" in
the Oracle Utilities Application Framework Administration Guide.
