Maintaining UI Components (Translation)
You can use the override fields on some of the system data tables to modify and customize the labels, buttons, titles, tab names and messages on the standard user interface. This may be helpful to correct minor interface inconsistencies and inappropriate translations as well as to provide translations for any single fixes that you may have applied to your environment. (Single fixes release without translation, so you may need to translate any labels and descriptions for new UI components or messages.)
You can manually modify the descriptions or translations of the following items:
- Dialog titles
- Transaction titles and tab labels
- Field labels on tab pages
- Button labels
- Messages
