App Server CM Packaging Tools
The following utilities are provided in this package for maintaining the packaging environment and creating release versions of customer modifications (CM):
extractCMSource utility, used to extract source from an app server or from a release or patch install package.
applyCM utility, used to apply a CM patch to a packaging environment.
create_CM_Release utility, used to create a full CM release version.
create_CM_Patch utility, used to create CM patch release version utility.
Instructions for using these utilities are described in the following sections.
