CM Packaging Utilities Cookbook
This document describes the installation, configuration, and operation of the packaging utilities provided with the Software Development Kit. These utilities enable developers to prepare releases of their custom modifications, called CM releases, to the products. Releases prepared using these utilities may be installed on top of an existing base product environment.
Note: CM releases will correspond to a specific base product
version and can only be installed on base product environments of
that version.  Customers installing a CM release must first verify
the corresponding base product version with the Implementation team.
Note: This document describes CM packaging utilities operation
for Oracle database only. The application server can be Unix or Windows/DOS
operating system. In Unix you must execute the script with .sh suffix, in window the script with .cmd suffix. They both
will execute the same Perl script with .plx suffix. For instance:
- applyCM.sh: Unix driver script
 - applyCM.cmd: Windows driver script
 - applyCM.plx: Perl script
All the examples in this document are related to Unix. If you are in Windows/DOS simply execute the same scripts, but using .cmd extension instead .sh.
