Maintaining Foreign Key References
You need to setup foreign key references if you have characteristics whose valid values are defined in another table (e.g., if you use "foreign key reference" characteristic types).
Note: For detailed information about foreign keys, see "Primary and Foreign Keys" in the Oracle Utilities Application Framework Administration Guide.
