Jump to main content
Oracle Utilities Application Framework Software Development Kit
Search
Home
Developer Guide
Public API
Maintenance Class Public Methods
User Guide
Developer Guide
Overview
Java Annotations
Public API
SQL Return Codes
Standard Business Methods
Business Entity Public Methods
UI Javascript User Exits
Java User Exits (interceptors) Interfaces and Classes
RequestContext Methods
Data Objects
Application Logs
Java Programming Standards
HQL Programming Standards
SQL Programming Standards
Database Design
System Table Guide
Key Generation
Development Performance Guidelines
Packaging Guide
Please refer to the Javadocs for the public API.
