Jump to main content
Oracle Utilities Application Framework Software Development Kit
Search
Home
Developer Guide
Database Design
Database Object Standard
Naming Standards
Sequence
User Guide
Developer Guide
Overview
Java Annotations
Public API
Application Logs
Java Programming Standards
HQL Programming Standards
SQL Programming Standards
Database Design
Naming Standards
Table
Columns
Indexes
Sequence
Trigger
Column Data Type and Constraints
Standard Columns
System Table Guide
Key Generation
Development Performance Guidelines
Packaging Guide
Sequence
The base sequence name must be prefixed with the owner flag value of the product.
