Replacing the Oracle Utilities Logo
Customers may want to replace the Oracle Utilities logo image on the Main menu with another logo image. To do this, put the logo <customer_logo_file>.gif file into the directory $SPLEBASE/etc/conf/root/cm
and create a new "External" Navigation Key called CM_logoImage.
To replace the logo, run the Oracle Utilities application from the browser with the parameters:
http://<hostname>:<port>/cis.jsp?utilities=true&tools=true
From the Admin menu, select Navigation Key. Add the above Navigation Key with its corresponding URL Override path.
The syntax for the URL path is:
For Windows:
http://<host name>:<port>/cm/<customer_logo_file>.gif
For UNIX:
http://<host name>:<port>/spl/cm/<customer_logo_file>.gif
The root directory may be deployed in war file format for the runtime environment (SPLApp.war
). Use the provided utilities to incorporate your cm
directory into the SPLApp.war
file.
