General guidelines
- Do not use reserved java words.
- Do not use spaces.
- Do not abbreviate.
- Do not use punctuation.
- Do not start the name with a number.
Here are our project guidelines for naming properties:
- Generally, do not abbreviate. The exceptions are SA, and SP, for when the name would
get too long if written as is. For example:
ServiceAgreement
, as part of a much longer field name. - In line with the above, spell out
amount
andtotal
. - Boolean values (SW) are prefixed with
is
,has
,can
,are
, orshould
, according to what is grammatically correct. - Date fields end with
Date
. - Time fields end with
Time
. - Datetime fields end with
DateTime
. - Id is spelled
Id
. - Do not include a final Flag (FLG) or Code (CD).
- Use
min
instead of minimum, andmax
instead ofmaximum
. - Can be generic. That is, for the field
BILL_STATUS
, you can just name itstatus
