PageBody aboutToRead(RequestContext, PageHeader)
This method is called before a service retrieves information.
Input
RequestContext- Contains session parameters, such as language cd, user id, and so on.
Input/Output
PageHeader- The data describing the information that should be read.
Return value
PageBodyornull- If a page body is returned, this is considered the result of the service and the underlying service will not be invoked. If null is returned, the underlying service will be invoked normally.
Throws
InterceptorError - Throw this exception when an error occurs.
InterceptorWarning - Throw this exception to signal an application
warning.
