EV Thanks Module
The EV Thanks module is used to tell the reader that driving an EV is impacting their community in a positive way. The module thanks the reader for driving an EV, and tells them that their community thanks them for helping to create a healthier environment, while also saving on fuel and maintenance costs.
Requirements
There are no module-specific requirements. For product requirements, see Requirements and Limitations for EV Charging Coach Emails.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Table 6-10 Configuration Options
| Configuration Option | Input Value |
Images The image can be configured to use client-specific colors. Other than that, the image can not be changed. |
Optional Specify client branding colors. |
To see how this module fits into the overall user experience, see Design and Configuration.
