Inbound Web Services
Inbound web services define the details of how messages are received from an external system. This includes incoming usage and device events, as well as messages sent from the Itron OpenWay application in response to a command request.
The following inbound web services must be configured in your system. If these are not present in your configuration, add them. Refer to the Oracle Utilities Application Framework documentation for more information about creating inbound web services.
Inbound Web Service Name
Description
D1-BulkRequestHeader
Bulk Request Header
D1-BulkRequestUpdate
Bulk Request Update
D1-BulkResponse
Bulk Response
D1-DeviceEventSeeder
Device Event Seeder
D1-DeviceStatusCheck
Device Status Check
D1-InitialLoadIMD
Used by OSB to instantiate an IMD
D1-PayloadErrorNotif
Payload Error Notification
D1-PayloadStatistics
Payload Statistics
D1-PayloadSummary
Payload Summary
D8-DetLoadSideVoltageMtrRslt
Itron - Detect Load Side Voltage by Meter Result
D8-DisconnectMeterResult
Disconnect Meter Result Service
D8-InterrogateByGroupResult
Itron - Interrogate By Group Result XIA
D8-PingByEndpointsMDResponse
Itron - Ping By Endpoints Multi-Device Response XAI Inbound
D8-PingByEndpointsResponse
Itron - Ping By Endpoints Response inbound web service
D8-ReadDisconStateMtrRslt
Itron - Read Disconnect State by Meter Result Service
D8-ReadResult
Itron - Contingency Read Result
D8-ReconnectMeterResult
Itron - Reconnect Meter Result Service
Note: The following apply to all of the above inbound web services:
Message Options
  • Trace: No
  • Debug: No
  • Active: Yes
Operations
  • Operation Name: Same as web service name
  • Schema Type: Business Object
  • Schema Name: Applicable business object code
  • Transaction Type: Add
