Outbound Message Types
Outbound message types define specific types of messages sent to an external system, such as messages containing device command requests.
The following outbound message types must be configured in your system. If these are not present in your configuration, add them. Refer to the Oracle Utilities Application Framework documentation for more information about creating outbound message types.
Description
D8-CONREAD
Itron Contingency Read By Endpoints
D8-INTRGRP
Itron Interrogate By Group
D8-COMM
Itron Commission
D8-DCOMM
Itron Decommission
D8-DSC
Itron Device Status Check
D8-DSCMD
Itron Device Status Check Multi Device
D8-DLSV
Itron Detect Load Side Voltage
D8-RCONN
Itron Remote Connect
D8-RDCONN
Itron Remote Disconnect
D8-RDSS
Itron Read Disconnect State
Note: The following apply to all of the above outbound message types:
  • Business Object: D1-OutboundMessage (Outbound Message)
  • Priority: Priority 50
