Inbound Web Services
Inbound web services define the details of how messages are received from an external system. This includes incoming usage and device events, as well as messages sent from the head-end system in response to a command request.
The following inbound web services must be configured in your system. If these are not present in your configuration, add them. Refer to the Oracle Utilities Application Framework documentation for more information about creating inbound web services.
 Inbound Web Service Name  |
 Description  |
 D1-BulkRequestHeader  |
 Bulk Request Header  |
 D1-BulkRequestUpdate  |
 Bulk Request Update  |
 D1-BulkResponse  |
 Bulk Response  |
 D1-DeviceEventSeeder  |
 Device Event Seeder  |
 D1-DeviceStatusCheck  |
 Device Status Check  |
 D1-InitialLoadIMD  |
 IMD Seeder  |
 D1-PayloadErrorNotif  |
 Payload Error Notification  |
 D1-PayloadStatistics  |
 Payload Statistics  |
 D1-PayloadSummary  |
 Payload Summary  |
 DG-ConDisconStChgNotification  |
 Initiate Connect Disconnect Response  |
 DG-OutageDetectionEventNotification  |
 Initiate Outage Detection Response  |
 DG-ReadingChangedNotification  |
 Reading Changed Notification  |
Note: The following apply to all of the above inbound web services:
Message Options
Trace: No
Debug: No
Active: Yes
Operations
Operation Name: Same as web service name
Schema Type: Business Object
Schema Name: Applicable business object code
Transaction Type: Add
