Processing Methods
Processing methods define the format or means by which a service provider receives and/or sends data from and/or to the application, including bill determinants, usage data, or device events. Processing methods are also used to define how to create information internal to the application such as initial measurement data and device events. Processing methods can also be used to define how command requests are sent to the head-end system.
The following types of processing methods must be configured for the head-end system service provider. Refer to the Oracle Utilities Service and Measurement Data Foundation documentation for more information about configuring processing methods.
Initial Measurement Creation
Initial measurement creation processing methods define the business objects used to create initial measurements. The IMD Seeder inbound web service uses this processing method to determine which type of initial measurement business object to instantiate when receiving usage from the head-end system.Device Event Mapping
Device event mapping processing methods define how head-end-specific device events are mapped to standard device event names. The Device Event Seeder inbound web service uses this processing method to determine which type of device event business object to instantiate when receiving device events from the head-end system.UOM Translation
UOM translation processing methods define how head-end-specific unit of measure (UOM) codes are mapped to standard UOM codes. This processing method is used to determine how to map head-end system UOM codes to standard UOM codes when receiving usage from the head-end system.Commands
Command processing methods define how command requests are sent to a head-end system. More specifically, they define the type of outbound communication business object to create for each type of command, and the outbound message type to send to the head-end system.
The following types of command processing methods can be configured for the head-end system service provider, based on the requirements of each implementation using the “How to Create OB COMM/Send OB Message” processing method business object (D1–HowToCreateActivityOBComm).
| Command | Processing Role | Default Business Object | Default Outbound Message Type |
 Device Commission  |
 Device Registration  |
 DG-MeterAddNotification  |
 Commission  |
 Device Decommission  |
 Device Removal  |
 DG-MeterRemoveNotification  |
 Decommission  |
 Device Status Check  |
 DG-InitiateOutageDetection  |
 Get Status  |
 On-Demand Read (Scalar)  |
 DG-InitiateMeterByMeterId  |
 Initiate Meter Read by Meter ID  |
 Remote Connect  |
 Remote Connect  |
 DG-InitiateConnectDisconnect  |
 Connect Device  |
 Remote Disconnect  |
 Remote Disconnect  |
 Disconnect Device  |
