Meter Administration Services
This section describes the meter administration services of the test harness composite.
AddMeters
This web service adds a set of meters to the in-memory data store. This will not permanently add it to the control file.
Input — AddMetersInput
Part: payload
Element: AddMetersRequest
 Parameter  |
 Description  |
 id  |
 The identification code for the meter.  |
 macID  |
 A MAC address that must be unique within the system.  |
 utility  |
 An informational string.  |
 serviceType  |
 One of the valid ServiceType values (see schema). "Electric" is the only option at this time.  |
 isCommissioned  |
 Whether or not the meter is in a commissioned state.  |
 loadActionCode  |
 One of the possible LoadActionCode values used in Connect and Disconnect (see schema).  |
 outageEventType  |
 One of the possible OutageEventType values used in Device Status Check (see schema).  |
 executionStatus  |
 One of the possible ExecutionStates (see schema). These values control how the meter will respond to commands.  |
 groupName  |
 The name linking multiple meters together into a set.  |
 jobExecutionStatus  |
 One of the possible Job Execution Status values (see schema). This attribute determines how requested jobs perform.  |
 updateIfExisting  |
 Whether or not to update the meter with the provided values if it already exists in the index.  |
 Comment  |
 An informational string describing the purpose of the meter.  |
 Channels  |
 A listing of unit of measures supported by this meter.  |
 uomCode  |
 A code describing the unit of measure for the channel.  |
 uomName  |
 A short string containing the name of the unit of measure.  |
 decimals  |
 The number of digits to the right of the decimal that should be generated when reading the meter.  |
 description  |
 A longer description of the unit of measure.  |
Output — AddMetersOutput
Part: payload
Element: AddMetersResult
Whether or not each meter was added to the index.
Fault — See UtilityFault
RemoveMeter
This web service removes a meter from the in-memory data store. This will not permanently remove it from the control file.
Input — RemoveMeterInput
Part: payload
Element: RemoveMeterRequest
 Parameter  |
 Description  |
 id  |
 The ID for the meter to be removed  |
Output — RemoveMeterOutput
Part: payload
Element: RemoveMeterResult
Whether or not the meter was removed from the index.
Fault — See UtilityFault. Thrown when meter id is not found.
AddMeterChannel
This web service adds a new channel to a single meter.
Input — AddMeterChannelInput
Part: payload
Element: AddMeterChannelRequest
 Parameter  |
 Description  |
 id  |
 uomCode  |
 uomName  |
 decimals  |
 description  |
Output — AddMeterChannelOutput
Part: payload
Element: AddMeterChannelResult
Whether or not the channel was added to the index.
RemoveMeterChannel
This web service removes a Channel from a meter.
Input — RemoveMeterChannelInput
Part: payload
Element: RemoveMeterChannelRequest
 Parameter  |
 Description  |
 id  |
 The ID for the meter to be removed.  |
 uomCode  |
 uomName  |
These three parameters are combined to locate a unique channel
Output — RemoveMeterChannelOutput
Part: payload
Element: RemoveMeterChannelResult
Whether or not the channel was removed from the meter.
ReadScalarMeter
This web service generates a scalar reading for each channel of a given meter.
Input — ReadScalarMeterInput
Part: payload
Element: ReadScalarMeterRequest
 Parameter  |
 Description  |
 id  |
 The ID for the meter to be read  |
Output — ReadScalarMeterOutput
Part: payload
Element: ReadScalarMeterResult
Zero or more scalar readings for the given meter.
 Parameter  |
 Description  |
 uomCode  |
 uomName  |
 decimals  |
 description  |
 value  |
 A random number representing the scalar reading.  |
