Implementing The To Do Entries
To enable the To Do entries visible in the To Do Type page, you must configure the system as follows:
  • Define the To Do roles associated with each To Do type and link the appropriate users to them. Once you have defined the roles appropriate for your organization's To Do types, remove the reference to this system default role F1_​DFLT. Refer to To Do Entries Reference A Role for more information.
  • For any To Do Type that is provided for a specific background process, the To Do simply needs to reference the appropriate Creation Background Process. When the background process is scheduled, To Dos are created based on the logic of the related background process. This applies to To Dos Created for Object-Specific Error Conditions and Dedicated To Do Background Processes.
  • For any To Do Type that is provided for creation by an algorithm or other process, there may be configuration required to populate that To Do type as an algorithm parameter or as an attribute on a control table.
    Note: Refer to the description of the To Do type for more information.
