Configuring VEE Groups
This portal is used to display and maintain a VEE Group.
Refer to Understanding VEE Groups for more information.
You can access the portal by selecting Admin, then VEE, then VEE Group. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
- VEE Group: Defines basic information about VEE group
 - VEE Rules List: lists the VEE Rules belonging to the group
 - Referencing VEE Rules List: lists the VEE Rules that reference the group
 - Referencing VEE Group Factors List: lists the VEE group factors that reference the group
 - Referencing Measuring Component Type List: lists the measuring component types that reference the group
 - Referencing Measuring Component List: lists the measuring components that reference the group
