Service Order Field Activity Processing
This section outlines how service order field activities are processed.
Pre-Processing, Validation, and Post-Processing Algorithms
When service order field activities are first instantiated, a set of pre-processing algorithms populate and derive information needed for the activity, such as the activity type, service point, device, address, effective date, and other information.
Validation algorithms validate this information when first retrieved and when updated.
When service order field activities are completed, a post-processing algorithm populates the activity end date/time.
Service Order Field Activity Lifecycle
As a service order field activity moves through its lifecycle, it triggers various business processes based on the type of service order field activity. The table below outlines the lifecycle for the Field Activity (D1-FieldActivity) business object.
 State  |
 Description  |
 Pending  |
 The initial state for service order field activities. An Enter algorithm sends an acknowledgement to the requesting system. The activity is transitioned to the next state via a monitor process.  |
 Validate  |
 Enter algorithms perform the following: Validate Activity Type (and transition to error if invalid) Derive and validate service order field activity recipient Validate duplicate and conflict service order field activities Derive and validate service order field activity service point Derive and validate service order field activity device Validate address constituents Check for any existing cut service restrictions The activity is transitioned to the next state via a monitor process.  |
 Validation Error  |
 If the business object fails any of the validations in the Pending state, it enters this state. Enter algorithms perform the following: Create a To Do based on specified To Do Type and To Do Role Set the "Allow Child to Transition Parent Activity" flag to “yes”. This allows the service order field activity to transition the parent orchestration activity if needed. Activities in this state can be corrected and retried.  |
 Waiting to Request  |
 If a service order field activity has a future effective date, it remains in this state until the effective date is reached. A Monitor algorithm transitions the activity to the next state when the activity's effective date time is reached (process date time >= effective date time). An Enter algorithm sets the "Allow Child to Transition Parent Activity Based On Effective Date" flag to “yes”. This allows the service order field activity to transition the parent orchestration activity if needed.  |
 Waiting for Appointment  |
 If the service order field activity passes its validations and the effective date has been reached, the activity enters this state. Enter algorithms perform the following: Evaluate if an appointment is required for field tasks of this type. If not, the activity transitions to the "Communication in Progress" state. Create a To Do if an appointment is necessary but the system is not able to send an appointment request. Set the "Allow Child to Transition Parent Activity" flag to “yes”. This allows the service order field activity to transition the parent orchestration activity if needed. Send a notification to the appointment handling system. Monitor algorithms perform the following: Verify if an appointment has been supplied. Send a notification to the appointment handling system. The activity is transitioned to the next state via a monitor process. See Waiting for Appointment for more information about this state.  |
 Communication in Progress  |
 Service order field activities enter this state following the "Waiting for Appointment" or "Retry" states. Enter algorithms perform the following: Create an outbound communication for the service order field activity (see Communication in Progress for more information). Set the "Allow Child to Transition Parent Activity" flag to “yes”. This allows the service order field activity to transition the parent orchestration activity if needed. Monitor algorithms perform the following: Check for existing child communications. Check that the activity hasn’t timed out.  |
 Discarded  |
 Activities discarded in other states enter this state. Enter algorithms perform the following: Cancel outstanding outbound communications. Cancel outstanding completion events. Populate the cancel reason. Send a failure notification to the requesting system. Transition the parent activity to the "Activity Error" state (see Service Order Orchestration Activity Lifecycle for more information). Check if a Cancel Orchestration activity is required.  |
 Communication Error  |
 If an outbound or inbound communication an Error state, the service order field activity enters this state. Monitor algorithms perform the following: Check that the activity hasn’t timed out. Enter algorithms perform the following: Create a To Do based on specified To Do Type and To Do Role. Set the "Allow Child to Transition Parent Activity" flag to “yes”. This allows the service order field activity to transition the parent orchestration activity if needed. Activities in this state can be corrected and retried.  |
 Retry  |
 When a service order field activity is retried after correction of an error condition, it enters this state. Enter algorithms perform the following: Check to determine if there are associated outbound communications in progress. Cancel any outstanding outbound communications.  |
 Execute Completion Events  |
 After an inbound communication is received, it enters this state. Enter algorithms perform the following: Executes completion events defined on the field task type (these completion events were initially created by the inbound communication). Evaluates the "Field Activity Completed" flag on the service order field activity. If this is set to "No", the service order field activity is transitioned to the "Canceled In Field" state. The activity is transitioned to the next state via a monitor process. See Execute Completion Events for more information about this state.  |
 Completion Event Error  |
 If an error occurs during completion event processing, the service order field activity enters this state. Monitor algorithms perform the following: Check that the activity hasn’t timed out. Enter algorithms perform the following: Create a To Do based on specified To Do Type and To Do Role. Set the "Allow Child to Transition Parent Activity" flag to “yes”. This allows the service order field activity to transition the parent orchestration activity if needed. Activities in this state can be corrected and retried.  |
 Completed  |
 Service order field activities enter this state when all completion events have successfully completed. Enter algorithms perform the following: Update the parent orchestration activity. Send a success response to the requester. Transition the parent orchestration activity to the next state in its lifecycle. Send a service order field activity completion outbound communication to subscribing systems.  |
 Canceled in Field  |
 If the "Field Activity Completed" flag on the field activity is set to "No", the service order field activity enter this state. Enter algorithms perform the following: Send a failed response to the requester. Transition the parent orchestration activity to the "Activity Error" state. Create a To Do to notify users that the service order field activity has been canceled.  |
When a service order field activity enters the "Wait for Appointment" state, it first determines if an appointment is necessary for the service order field activity. If not, the activity moves on to the "Communication in Progress" state (see below).
If an appointment request cannot be sent for some reason, the service order field activity creates a To Do item to alert a user to attempt to manually request an appointment. Otherwise, the service order field activity sends an outbound message to the field work system requesting an appointment. based on the appropriate processing role defined on the."Send Notification to Appointment Handling System - Enter" algorithm.
 Processing Role  |
 Outbound Communication Business Object  |
 Appointment Response (default) Used if: An appointment is required and needs to be scheduled Appointment has been set  |
 Send Appointment Response Outbound Message (D1-SendApptRespOutboundMsg) Note: An outbound message must be created based on this business object.  |
The response from the field work system can be received by creating an Inbound Web Service that references the "Book selected appointment to Field Activity" (D1-BookAppt) service script.
While in this state, monitor algorithms verify if an appointment has been supplied and send notifications to the field work system.
Service order field activity communications are records of messages sent between Service Order Management and an external field work system. Communications can flow both outbound and inbound.
See Service Order Field Activity Communication for more information about service order field activity communication.
Manually Completing Service Order Field Activities
Service order field activities in the "Communication in Progress" state can be manually completed or canceled by clicking Complete in the Record Actions section of the Activity zone. This opens the Field Activity Manual Completion page where the user can enter appropriate details to manually complete the field activity (such as completion information, service point information, device information, and so on). When submitted, this page creates an inbound communication and transitions the field activity to the next state as appropriate.
Note: Implementations can define custom service scripts for each field task type in the Manual FA Completion Controls section on the Field Task Type extendable lookup to customize the sections displayed on the Field Activity Manual Completion page.
After receiving the inbound communication, the service order field activity enters the "Execute Completion Events” state.
The inbound communication will have previously created completion events for the service order field activity, based on those defined on the field task type or those referenced by field activity remarks. These creation events begin in the "Pending" state.
An Enter algorithm transitions completion events associated with the service order field activity into their "Executed" state.
