Defining Configurations
You use the Configuration portal to display and maintain configurations.
Refer to Understanding Configurations for more information.
You can access the portal by selecting Admin, then Configuration Report, then Configuration. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
- Configuration: This zone provides information about the selected configuration.
 - Configuration Attachments: This zone lists any attachments defined for the configuration.
