Configuring Measurement Cycle Schedules
This portal is used to display and maintain a Measurement Cycle Schedule.
You can access the portal by selecting Admin, then Device Installation, then Measurement Cycle Schedule. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
  • Measurement Cycle Schedule Query: This zone allows you to query for Measurement Cycle Schedules based on Measurement Cycle and select the desired record.
  • Measurement Cycle Schedule: This zone provides information about the selected Measurement Cycle Schedule.
