Example: Itron Commissioning Process
This section provides an example of a synchronous command, the commission device command supported by the Itron OpenWay adapter.
The Itron OpenWay 3.9 command for registering a meter (commissioning a device) in the system is AddMeterDefinitions in the www.itron.com.ami.2008.10.provisioning.wsdl definition. The Smart Grid Gateway Adapter for Itron OpenWay typically sends a meter serial number and some other configuration data. The response indicates whether or not an error was encountered.
The image below illustrates the process flow used by this command.
![](../images/Itron-AddMeterDefinition.jpg)
Below is a summary of the important features of the Smart Grid Gateway implementation of this command. Many of the concepts can be applied when creating a custom synchronous command.
Command Activity — Device Commissioning
Business Object: D1-DeviceCommissioning
Lifecycle and Algorithms
The table below outlines some of the important algorithms used by the Device Commissioning command activity.
Lifecycle State | Algorithms |
Validate |
The important features here are not the specific algorithms, but rather the ability to perform validation logic at a process level.
Commission Ready |
Several algorithms in this state are designed to create outbound communications to the head end system based on various conditions.
Communication In Progress |
Execute Completion Events |
Outbound Communication — Itron - Add Meter Definition (Commission)
Business Object: D8-AddMeterDefinitionsDR
Schema
The portions of the schema that contain the payload of the web service request and response communications are the sendDetail element (constructed using the D8-AddMeterDefinitionsDRDA data area) and the responseDetail element (constructed using the D8-AddMeterDefRespDRDA data area). The XSLs used to create or decipher XML conforming to the Itron structure use these elements as a basis.
The table below outlines some of the important algorithms used by the Add Meter Definition outbound communication.
Validate |
Awaiting Response |
Response Error |
The business object will transition to this state if the reply indicates a failure.
Create Completion Event |
Completed |
Message Sender XSLs
Outbound messages created by Add Meter Definition outbound communication use the following XSL files:
- Request XSL: D8-CommissionRequest.xsl
- Response XSL: D8-CommissionResponse.xsl
Refer to Creating Message Senders for more information about creating message senders.
