Configuring Processing Methods
In order to send smart meter commands to a head end system, appropriate processing methods must be configured on the head end system record. The tables below list the details appropriate to configuring processing methods for each command.
This table includes the following:
  • Command: The command you wish to configure. When a command is initiated for a device, the system creates a command activity.
  • Processing Role: The Processing Role appropriate for the command to be configured.
  • Business Object: The outbound communication business object to be created by the command activity. Note that most commands have separate business objects for the initial command request and the result request.
  • Outbound Message Business Object The business object that should be used when creating outbound message types for each command. Note that most commands use separate business objects for the initial outbound message type and the result outbound message type.
Itron OpenWay Processing Methods
This table lists the details appropriate to configuring processing methods for each command supported for the Itron OpenWay head end system.
Command
Processing Role
Business Object
Device Commissioning
Device Registration
Itron - Add Meter Definition
(D8-AddMeterDefinitionsDR)
Outbound Message for Itron Commission
D8-ItronCommissionOutboundMsg
Device Decommissioning
Device Deregistration
Itron - Deregister Meter
(D8-DeregisterMeterDR)
Outbound Message for Itron Decommission
D8-ItronDecommissionOutbndMsg
Remote Connect
Remote Connect
Itron - Reconnect Meter (Remote Connect)
D8-ReconnectMeterDR)
Outbound Message for Itron connect command
D8-ItronRemoteConnectOutbndMsg
Get Remote Connect Result
Itron - Reconnect Meter Result
(D8-ReconnectMeterResult)
Outbound Message for Itron connect result command
(D8-ItronRemoteCntRsltOutMsg)
Remote Disconnect
Remote Disconnect
Itron - Disconnect Meter
(D8-DisconnectMeterDR)
Outbound Message for Itron disconnect command
D8-ItronRemoteDisconnectOutMsg
Get Remote Disconnect Result
Itron - Disconnect Meter Result
(D8-DisconnectMeterResult)
Outbound Message for Itron disconnect result command
(D8-ItronRemoteDcntRsltOutMsg)
On-Demand Read (Scalar)
Itron - Contingency Read (Scalar)
(D8-ReadScalarDR)
Outbound Message for Itron Contingency Read command
D8-ItronOnDemandReadOutbndMsg
Get On-Demand Read Result
Itron - On Demand Read Result
(D8-ReadOnDemandReadResultDR)
O/B Msg for Itron Contingency Read Result
(D8-ItronOnDemandReadRsltOBMsg)
On-Demand Read (Interval)
Itron - Contingency Read (Interval)
(D8-ReadIntervalDR)
(D8-ItronOnDemandReadOutbndMsg)
Scheduled Read (Scalar)
Send Schedule Read Request
Itron - Interrogate by Group (Scalar)
(D8-InterrogateByGroupDR)
Outbound Message for Itron Schedule Read command
(D8-ItronInterrogateByGrpOBMsg)
Get Schedule Read Result
Itron - Interrogate by Group Results
(D8- InterrogateByGroupResultDR)
Outbound Message for Itron Schedule Read Result command
(D8-ItronInterrogateByGrpRsltOB)
Scheduled Read (Interval)
Itron - Interrogate by Group (Interval)
Device Status Check
Device Status Check
Itron - Ping by Endpoints (Status Check)
(D8-PingByEndpointsDR)
Outbound Message for Itron Device status check
(D8-ItronDvcStatusChkOutbndMsg)
Get Device Status Check Result
Itron - Ping By Endpoints Result
(D8- PingByEndpointsResultDR)
O/B Msg for Itron DeviceStatusCheck Result
(D8-ItronDvcStatusChkRstlOBMsg)
Multi-Device Status Check
Itron - Ping By Endpoints Multi-Device
(D8-PingByEndpointsMultiDvcDR)
Outbound Message for Itron Multi device status check
(D8-ItronDvcStChkMtDvcOutbndMsg)
Get Multi-Device Status Check Result
Itron – Ping By Endpoints Multi Dvc Result
(D8- PingByEndpointsMDResultDR)
O/B Message for Itron MultiDeviceStatusCheck Result
(D8-ItronDvcStChkMtDvcRsltOBMsg)
Load Check
Load Check
Itron - Detect Load Side Voltage
(D8-DetectLoadSideVoltgeByMtrDR)
Outbound Message for Itron Detect Load Side Voltage
(D8-ItronDetectLoadSideVolOBMsg)
Get Load Check Results
Itron – Detect Load Side Voltage Result
(D8- DetLoadSideVoltageMtrRsltDR)
Outbound Message for LoadCheckResult Cmd
(D8-ItronDetLSVoltMtrRsltOutMsg)
Landis+Gyr Processing Methods
This table lists the details appropriate to configuring processing methods for each command supported for the Landis+Gyr head end system.
Command
Processing Role
Business Object
Device Registration
L+G Add Meter to Inventory(MultiSpeak)
(D3-AddMeterToInventryMultiSpDR)
LG - Add Meter To Inventory OB Message
D3-AddMeterToInventoryOBMsg
Device Removal
L+G Meter Remove Notification (MultiSpeak)
(D3-MtrRmvNotifMultiSpeakDR)
LG - Meter Remove Notification OB Message
(D3-MeterRemoveNotifOBMsg)
Meter Retire
L+G Meter Retire Notification
(D3-MeterRetireNotificationDR)
LG - Meter Retire Notification OB Message
(D3-MeterRetireNotifOBMsg)
Meter Exchange
Device Installation
L+G Meter Exchange Notification
(D3-MeterExNotificatnMultiSpDR)
LG -Meter Exchange Notification OB Message
(D3-MeterExchNotificatnOBMsg)
Remote Connect
Remote Connect
L+G Initiate Connect Disconnect DR
(D3-InitiateConnectDisconnectDR)
L+G Initiate Connect Disconnect OB Message
(D3-InitConnectDisconnectOBMsg)
Remote Disconnect
Remote Disconnect
Demand Reset
Demand Reset
L+G Schedule Demand Reset (Multispeak)
(D3-ScheduleDemandResetDR)
LG - Schedule Demand Reset OB Message
(D3-ScheduleDemandResetOBMsg)
On-Demand Read (MultiSpeak)
L+G MultiSpeak Initiate Meter Read By Meter Num Direct Route
(D3-InitiateMRByMtrNbrDR)
L+G MultiSpeak InitiateMeterReadByMeterNumber OB Message
(D3-InitMtrReadByMtrNumOBMsg)
On-Demand Read (Interval) [CIM]
CIM Meter On Demand Read Direct Route (Interval)
(D3-CIMGetLPDataDR)
CIM AMIRequest GetMeterReads OB Message
(D3-CIMAMIRequestGetMtrRdOBMsg)
On-Demand Read (Scalar) [CIM]
CIM Meter On Demand Read Direct Route (Scalar)
(D3-CIMMeterOnDemandReadDR)
Device Status Check
Device Status Check
CIM Ping Direct Route
(D3-CIMPingDR)
Sensus Processing Methods
This table lists the details appropriate to configuring processing methods for each command supported for the Sensus head end system.
Command
Processing Role
Business Object
Device Registration
Sensus -Meter Add Notification Direct Route
(D6-MeterAddNotificationDR)
Sensus - Meter Add Notification OB Message
D6-MeterAddNotificationOBMsg
Device Removal
Sensus -Meter Remove Notification Direct Route
(D6-MeterRemoveNotificationDR)
Sensus -Meter Remove Notification OB Msg
(D6-MeterRemoveNotificatnOBMsg)
Remote Connect
Remote Connect
Sensus - Initiate Conn Discon - DR
(D6-InitiateConnectDisconnectDR)
Sensus Initiate Connect Discon OB Message
(D6-InitConnectDisconnectOBMsg)
Remote Disconnect
Remote Disconnect
Sensus - Initiate Meter Read By Meter ID
(D6-InitiateMeterByMeterIdDR)
Sensus MultiSpeak InitiateMeterReadByMeterNumber OB Message
(D6-InitMtrRdMtrIdOBMsg)
Device Status Check
Device Status Check
Sensus Initiate Outage Detection DR
(D6-InitiateOutageDetectionDR)
Sensus InitiateOutageDetection OB Message
(D6-InitOutageDetectionOBMsg)
Silver Spring Networks Processing Methods
This table lists the details appropriate to configuring processing methods for each command supported for the Silver Spring Networks head end system.
Command
Processing Role
Business Object
Device Registration
SSN - Replace Location (D7-ReplaceLocationDR)
SSN - Replace Location (Comm) OB Message (D7-ReplaceLocationOBMsg)
Device Removal
SSN - Replace Device At Location (Decomm) (D7-ReplDeviceAtLocForDecommDR)
SSN - Replace Device At Loc O/B Message: (D7-ReplaceDeviceAtLocOBMsg)
Remote Connect
Remote Connect
SSN - Add Remote Provisioning Job - Polling (D7-AddRemoteProvJobDRP)
SSN - Connect Disconnect OB Message (D7-ConnectDisconnectOBMsg)
SSN - Connect Disconnect Results (D7-ConnectDisconnectResultDR)
SSN - GetConnectDisconnectResult OB Message (D7-GetCntDiscntResultOBMsg)
Remote Disconnect
Remote Disconnect
SSN - Add Mtr Read Job (Scalar) - Polling (D7-AddMeterReadJobScalarDRP)
SSN - Add Meter Read Job Scalar OB Msg Type
D7-AddMeterReadJobScalarOBMsg
Get On-Demand Read Result (Scalar)
SSN - Meter Read Results (Scalar)
(D7-MeterReadResultsScalar )
SSN - GetMeterReadResults(Scalar) By JobId
(D7-GetSMtrRdRsltJobIdOBMsgTyp )
SSN - Add Mtr Read Job (Interval) - Polling (D7-AddMeterReadJobIntervalDRP)
SSN - AddMeterReadJob Interval OB Msg Type
(D7-AddMtrReadJobIntervalOBMsg )
Get On-Demand Read Result (Interval)
SSN - Meter Read Results (Interval)
(D7-MeterReadResultsInterval )
SSN - GetMeterReadResults(Interval) By JobId
(D7-GetIMtrRdRsltJobIdOBMsgTyp )
Device Status Check
Device Status Check
SSN - Add Ping Job - Polling (D7-AddPingJobDRP)
SSN - Add Ping Job OB Message (D7-AddPingJobOBMsg)
SSN - Ping Results (D7-PingResultsDR)
SSN - Get Ping Results O/B Message (D7-GetPingResultsOBMsg)
Get Job Status
Get Job Status
SSN - Get Job Status for Polling (D7-GetJobStatusDRP)
SSN - Get Job Status Outbound Message (D7-GetJobStatusOutboundMsg)
