Configuring Landis+Gyr Extendable Lookups
Note: This section applies to both middleware and native implementations of the Smart Grid Gateway Adapter for Landis+Gyr.
This section outlines some of the extendable lookups that must be configured for use with the Landis+Gyr adapter. Refer to the Oracle Utilities Application Framework documentation for more information about working with extendable lookups.
CIM Response Status Extendable Lookup
The CIM Response Status extendable lookup is used to map descriptions to response status codes received from the L+G Command Center. Each value defined for the CIM Response Status extendable lookup should include the following:
  • Response Status: The CIM status code for the response status
  • Description: A description of the response status
  • Status: The status of the lookup value (can be Active or Inactive)
CIM Data Source Extendable Lookup
The CIM Data Source extendable lookup is used to map descriptions to data sources defined in the L+G Command Center. Each value defined for the CIM Data Source extendable lookup should include the following:
  • Data Source: The CIM code for the data source
  • Description: A description of the data source
  • Status : The status of the lookup value (can be Active or Inactive)
Device Event Mapping
The Device Event Mapping extendable lookup is used to determine which type of device event business object to instantiate when receiving device events from the head-end system. Each value defined for the Device Event Mapping extendable lookup should include the following:
  • Head-End System Event Name: The event name used by the head-end system
  • Description: A description of the device event
  • Standard Event Name: The standard event name for device events of this type, from the “Standard Event Name” extendable lookup.
UOM Code to Standard UOM Mapping
Usage received from a utility’s head-end system may use utility-specific unit of measures (UOMs). These custom UOMs must be mapped to standard UOM codes. The UOM Code to Standard UOM Mapping extendable lookup is used for this purpose. Each value defined for the UOM Code to Standard UOM Mapping extendable lookup should include the following:
  • Head-end UOM: The unit of measure code used by the head-end system.
  • Unit of Measure: The unit of measure defined in the system.
  • Description: A description of the unit of measure code.
Interval Status Code to Condition Mapping
Interval usage received from the Landis+Gyr Command Center can include interval status codes that indicate the status or condition of the interval value. These interval status codes must be mapped to standard condition codes in the system. The Landis+Gyr Interval Status Code to Condition Mapping extendable lookup is used for this purpose. Each value defined for the Landis+Gyr Interval Status Code to Condition Mapping extendable lookup should include the following:
  • Interval Status: The interval status code
  • Condition: The condition code to which the interval status code is to be mapped, from the Measurement Condition extendable lookup.
  • Description: A description of the interval status code.
