External System
External systems represent external applications with which the Smart Grid Gateway will exchange messages or data. In the case of the Smart Grid Gateway adapters, external systems represent the head-end systems with which the adapters communicate.
An external system that represents the Sensus RNI must be present in your system. If this is not present in your configuration, add it, along with the following Outbound Message Types. Refer to the Oracle Utilities Application Framework documentation for more information about creating external systems.
External System - Sensus:
  • External System: Sensus
  • Description: Sensus
  • Outbound Message Types:
Description
Message Sender
D6-CONDISCON
Sensus Initiate Connect Disconnect
D6-CONDISCON
D6-INITMTR
Initiate Meter Read By Meter ID
D6-InitMID
D6-INTOUTDET
Initiate Outage Detection Request
D6- INTOUTDET
Note: The following apply to all of the above outbound message types:
  • Processing Method: Real-time
  • Message XSL: D6-Request xsl
  • Response XSL: D6-Response.xsl
