Device Communication Base Package Business Objects
The adapter development kit base package includes the following communication business objects:
 Business Object Name  |
 Description  |
 DG-ConnectDisconStateChgNtf  |
 Generic - Connect/Disconnect State Change  |
 DG-InitiateConnectDisconnect  |
 Generic - Initiate Connect Disconnect  |
 DG-InitiateMeterByMeterId  |
 Generic - Initiate Meter Read By Meter ID  |
 DG-InitiateOutageDetection  |
 Generic - Initiate Outage Detection  |
 DG-MeterAddNotification  |
 Generic - Meter Add Notification  |
 DG-MeterRemoveNotifcation  |
 Generic - Meter Remove Notification  |
 DG-OutageDetectEvtNotification  |
 Generic - Outage Detection Event Notification  |
 DG-ReadingChgNotification  |
 Generic - Reading Changed Notification  |
Event Data Mapping
The head-end system event file format can map as follows into the business object, D1-DeviceEventMappingLookup:
 Head-End System Flat File Field  |
 Device Event Seeder BO Element  |
 Comments  |
 Transaction ID (from Header record)  |
 External Source Identifier  |
 This is the file name.  |
 Device Identifier  |
 External Device Identifier  |
 Event Name  |
 External Event Name  |
 Event Creation Date/Time  |
 Event Date/Time  |
 Device Type  |
 External Device Type  |
 This element has no real bearing on the device type within MDM/SGG. Its valid values include (although the element itself is free-form): Meter Collector Router  |
 Service Location ID  |
 External Service Location ID  |
 Communication Module Serial Number  |
 External Communication Module Identifier  |
 Event Category ID  |
 External Event Category  |
 Event Severity  |
 External Event Severity  |
 Valid values include (although the element itself is free-form): Alert Information  |
 Status Value  |
 External Status Value  |
 This represents additional information that relates to the event itself.  |
 Status Date/Time  |
 External Status Date/Time  |
 The date & time at which the additional information referenced above had occurred.  |
