FileProcessor Interface
This section contains a portion of the FileProcessor interface related to the file parsing functionality.
package com.splwg.d1.sgg.osb.common;
public interface FileProcessor {
    public enum TransactionType {
        USAGE, EVENT
     * FileParser usage method
     * @return a string containing the name of currently processed inbound file
    String getOrigin();
     * FileParser usage method Creates a file in the Error Folder and saves
     * passed row parameter to it
     * @param position
     *            the number representing the position in file where invalid
     *            raw data is started
     * @param row
     *            the byte array containing an invalid raw data in vendor
     *            specific format the same with format of incoming file
     * @param failCause
     *            the string showing the cause of fail It will be used while
     *            logging the fail message.
    void saveInvalidRow(long position, byte[] row, String failCause);
     * Returns the current offset in input file
    long getCurrentInputPosition();
