Application Security
The system restricts access to transactions or explicit services using an
 application service. The following points highlight what may be secured.
• The following points highlight security related to viewing and modifying individual records in the system:
◦ All
maintenance objects define an application service that includes the basic actions available, typically
Add,
Change,
Delete, and
Inquire. The base product supplies an application service for every maintenance object. Note that the application service for the maintenance object is defined on its related
service program.
 ◦ For maintenance objects whose user interface page is not portal-based, the application service also controls whether the menu entry appears. If a user doesn't have access to the maintenance object's application service, the menu item that corresponds with the application service will not be visible.
◦ For portal based user interfaces, each main (stand-alone)
portal defines an explicit application service with the access mode
Inquire, allowing the user interface to be secured independently of the underlying object security. If a user doesn't have access to the portal's application service, the menu item that corresponds with the application service will not be visible. The base product supplies an application service for every portal that is accessible from the menu. Note that the application service for the portal is defined on its related
service program, which is derived via its navigation option and navigation key.
 ◦ Menu items may define an application service / access mode. Typically the security supplied for portals and maintenance objects provides enough granularity to suppress menu items that a user does not have access to. Linking an explicit application service / access mode will further suppress the menu item under one of the following scenarios:
 ▪ Suppress a menu item if the underlying application security for the transaction does not provide enough fine grained control. For example, imagine your implementation creates a special BPA script to add a To Do Entry and would like users to use the special BPA rather than the base supplied Add dialogue for To Do Entry. The underlying security settings for To Do Entry should grant Add access to these users given that the special BPA will still add a record. To suppress the base Add dialogue, link a special application service and access mode for the base supplied menu item for To Do Entry Add. Then define a menu entry for the new special BPA for adding.
▪ Suppress the add option if a user does not have add security for the object. By default the product does not suppress the add function if a user does not have add access to the object. Rather, the user is prevented from adding the record at the back-end. If your implementation would like to suppress the menu option, link the object's application service and the Add access mode to the Add menu item.
The base product does not typically provide menu items with application services configured. Implementations may add this configuration if one of the above scenarios exist.
◦ Zones define an application service.
 ▪ For zones linked to a portal, if a user doesn't have access to the zone's application service, the zone will not be visible on the portal. In most cases the zone is delivered with the same application service as its portal. In special cases, such as the zones on the Dashboard, the product supplies separate application services for each zone allowing implementations to determine at a more granular level which users should have access to which zones.
▪ For query zones that are configured on a multi-query zone, if a user doesn't have access to the zone's application service, the zone will not be visible in the dropdown on the multi-query zone. In most cases all zones in a multi-query zone define the same application service as the multi-query zone. The product may supply a special application service for one or more zones in a multi-query zone if the functionality is special to certain markets or jurisdictions and not applicable to all implementations.
▪ For zones that are used by business services to perform SQL queries, the product supplies a default application service. Security for these zones is not checked by the product as they are used for internal purposes.
◦ For portal based pages, individual elements may be shown or hidden based on security using the
oraHasSecurity function in a UI map's HTML or in UI Hints in a schema. Refer to
Check User's Security Access for more information.
 ◦ Business objects define an application service. If the business object defines a lifecycle, the application service must include access modes that correspond to each state. In addition, the standard maintenance object access modes of
Add,
Change,
Delete and
Inquire are included. The base product business objects are supplied with appropriate application services. In addition, implementations may override the configured application service if desired.
 ◦ Batch controls define an application service which provides the ability to secure submission of individual batch processes. The application service must include an access mode of
Execute. The base product batch controls are supplied with appropriate application services. These services will typically have an ID that matches the batch control ID.
 ◦ Report Definition records define an application service. The application service must include an access mode of
Submit / View Report.
 • The following objects are securable but are typically executed via internal processes. The security is provided to ensure that any access to the objects from an external source is secured.
◦ BPA scripts may define an application service with the access mode
Execute. The base BPA scripts are typically not configured with any application service. An implementation may define one. Note that as mentioned above, a menu item may also be configured with an application service and access mode. This allows for a BPA that is invoked via a menu entry to be secured in more than one way.
 ◦ Business Services and
Service Scripts define an application service with the access mode
Execute. This is needed for services that may be executed from an external system, for example via an inbound web service. Base business services and service scripts that are linked to an inbound web service are configured with special application service. All other business services and service scripts are delivered with a default application service, which may be overridden by an implementation.
 ◦ Scripts may also check security within an Edit Data step type if there is some functionality that should or should not execute based on a user's security access. The Edit Data step would include a call to the business service F1-CheckApplicationSecurity
◦ Service Programs define an application service. As mentioned above, for Portals and Maintenance Objects, their application service is taken from the related service program. In base, specific application services are released for each of these types of service programs. All other service programs are typically delivered with a default application service, which may be overridden by an implementation. Note that for service programs linked to a Business Service, the application service on the business service takes precedence when invoking the business service.
 Users are granted access to application services via
user groups. For example, you may create a user group called Senior Management and give it access to senior manager-oriented pages and portals.
• When you grant a user group access to an application service with multiple access modes, you must also define the access modes that are allowed. Often the access modes correspond to an action on a user interface. For example, you may indicate a given user group has
inquire-only access to an application service, whereas another user group has
add,
change,
cancel and
complete access to the same service. Refer to
 action level security for more information.
 • If the application service has
 field level security enabled, you must also define the user group's security level for each secured field on the transaction.
 • And finally, you link individual
 users to the user groups to which they belong. When you link a user to a user group, this user inherits all of the user group's access rights.
 Parent topic
