Meter Data Management Configuration Setup Sequence
This section provides the suggested order for the setup of Meter Data Management and Smart Grid Gateway administrative data.
Entity
Description
1
Feature Configuration
These are options that can be set to impact system processing. Typically these have wide ranging impact across several modules (e.g., multi-time zone support)
1
Country
Your organization's country.
1
Currency
Your organization's native currency.
1
Display Profile
Controls how dates, times, and numbers displayed.
1
Language
The language to use for this implementation.
1
Time Zone
Your organization's base time zone.
1
Work Calendar
The work calendar for your organization, which identifies your public holidays.
2
Installation Options
Control various global aspects of the system.
2
To Do Role
Used to associate users with To Do entries.
2
To Do Type
Used to define types of To Do Entries.
3
User
Defines a user's user groups, data access roles, portal preferences, default values, and To Do roles.
3
User Group
A group of users who have the same degree of security access.
3
Service Type
Defines specific types of service for which usage can be recorded and captured (electric, gas, steam, etc.).
4
Division
Delineates between different operating companies within a large conglomerate of utilities.
4
Unit of Measure
Quantities measured and recorded by the system (CCF, KWH, KW, etc.).
4
Service Quantity Identifier
Used to further distinguish between measured quantities that have identical UOM/TOU combinations.
4
Time of Use
Modifiers for a given unit of measure that indicate a period of time during which a quantity has been used (On- Peak, Off-Peak, etc.).
4
Factor
Centrally stored sets of values for use in validation rules, bill determinants calculations, and other processes.
4
Market
Defines jurisdictions or regulatory environments in which a Service Point participates.
4
Measurement Cycle
Defines the schedule for manual meter reading of devices at Service Points in that cycle
4
Measurement Cycle Schedule
Define the dates on which devices are scheduled to be read for a given measurement cycle.
4
Outbound Message
Defines messages sent to external systems.
4
Processing Timetable Type
Defines types of schedules that can be referenced by different processes and objects.
5
External System
Defines External Systems with which Oracle Utilities Meter Data Management should be able to communicate.
6
Head End Systems
External Applications
Market Participants
External entities that serve various roles relative to the application (head-end systems, billing systems, market participants, outage management systems, etc.).
6
Contact Type
Defines properties of a class of entities (businesses, persons).
7
Activity Type
Defines properties common to a specific type of activity.
7
Communication Type
Define properties common to a specific type of communication.
7
Service Task Type
Defines specific types of tasks performed by external users (self-service meter reads, self-service outage notifications, etc.)
7
Dynamic Option Type
Defines information common to dynamic options of a specific type.
7
Manufacturer
Individual companies that makes devices. Manufacturers also reference models.
7
Exception Type
Defines properties common to VEE Exceptions of a specific type.
8
VEE Group
Collections of VEE Rules that are applied to initial measurement data.
9
VEE Rule
Standard and custom VEE Rules that perform checking and/or manipulation of initial measurement data.
10
VEE Eligibility Criteria
Dictates whether a VEE Rule can execute based on a set of defined criteria.
11
Measuring Component Type
Defines the most important properties of a measuring component.
11
Measuring Component Comparison Type
Defines details by which measuring component data can be compared to determine the days that most closely resemble a specific day being evaluated.
12
Device Configuration Type
Defines properties of Device Configurations of a given type.
13
Device Type
Defines information about a class of devices.
14
Service Point Type
Defines specific types of points at which service is delivered.
14
Service Point Quantity Type
Defines types of quantities that can be stored for a service point.
14
Usage Subscription Quantity Type
Defines types of quantities that can be stored for a usage subscription.
15
TOU Group
Used to limit the set of Time Of Uses that are usable in a TOU schedule.
16
TOU Map Template
Schedules used for TOU map data generation.
17
TOU Map Type
Define important properties of TOU maps of a given type.
18
Usage Transaction Exception Type
Defines properties common to Usage Transaction Exceptions of a specific type.
18
Usage Calculation Group
Collections of usage calculation rules that are applied to measurement data to calculate bill determinants for Usage Subscriptions.
19
Usage Calculation Rule
Defines rules that perform calculations on measurement data to generate bill determinants and other values used by external systems.
20
Usage Calculation Rule Eligibility Criteria
Dictates whether a usage calculation rule can execute based on a set of defined criteria.
21
Usage Subscription Type
Defines collections of properties common to a set of Usage Subscriptions.
22
Data Source
Defines the source of data for dynamic aggregation, such as measurement data from usage subscriptions linked to a service point, badged or unbadged items, or measuring component sets
22
Dynamic Aggregation Measuring Component Type
Define the most important properties of a measuring component used with dynamic aggregation.
22
Measuring Component Set
Define the dimensions and criteria by which dynamic aggregation will be performed.
22
Aggregation Group
Define the ordering of a series of related aggregations based on a set of configured measuring component Sets.
23
Settlement Subscription Type
Defines collections of properties defining a class of settlement subscriptions.
23
Settlement Unit
Defines the “lowest common denominator set” of dynamic aggregation dimensions.
23
Settlement Calculation Group
Defines collections of settlement calculation rules that are used to perform settlement calculations, including calculating service point quantities, totaling consumption and usage for settlement units, application of losses, and allocation of unaccounted for energy (UFE).
23
Settlement Calculation Rule
Defines rules that perform settlement calculations, including calculating service point quantities, totaling consumption and usage for settlement units, application of losses, and allocation of unaccounted for energy (UFE).
23
Settlement Item Type
Defines specific types of end-customer settlement accounts.
23
Market Contract Type
Defines specific types of market contracts used in settlement processing.
23
Market Product Set
Defines the highest level grouping for a set of market products that will be processed together.
23
Market Product Type
Define types of products used in settlement processing.
23
Attribute Data Snapshot
Define types of attribute data snapshots used in settlement processing.
23
Measurement Data Snapshot
Define types of measurement data snapshots used in settlement processing.
24
Processing Methods
Control various behaviors for external applications, head end systems, and market participants within the system such as which message is sent, how an external value is translated, among others.
24
Master Configuration
Configuration that applies to series of modules that acts as a central point of configuration rather than embedding repetitive configuration throughout a set of algorithms.
24
Information Lifecycle Management
Information Lifecycle Management (ILM) is designed to address data management issues, with a combination of processes and policies so that the appropriate solution can be applied to each phase of the data's lifecycle.
24
Analytics
Defines the extract parameters, the bucket configurations and configuration snapshots used for extracting data for Oracle Utilities Analytics
