Silver Spring Networks Web Service Authentication
The Silver Spring Neworks AMM API does not support Inbound Requests (from the SilverSprings server to Smart Grid Gateway). Outbound requests should utilize standard basic HTTPS authentication options via the HTTP Login User and HTTP Login Password parameters on the Context tab of the Message Sender portal.
![Screen capture showing the HTTP Login User and HTTP Login Password parameters on the Context tab of the Message Sender portal.](../images/SGG_Native_Authentication_SSN-Message_Sender.jpg)
