Maintaining Asset Completion Events
You use the Completion Event portal is used to display and maintain asset completion events.
Refer to About Asset Completion Events for additional functional information.
You can access the portal by selecting Menu, then Asset Management, then Asset Completion Event. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
- Completion Event: This zone displays the basic attributes of the asset completion event.
- Completion Event Related Objects: This zone displays objects related to the asset completion event, such as a device, service point, or initial measurement.
- Attachments: This zone displays attachments, if any, related to the asset completion event.
The following zones may appear as part of the portal's Log tab page:
- Completion Event Log: This zone displays the server logs for the asset completion event.
Note: The Completion Event portal may display
tabs and zones beyond those described here. These tabs and zones are
not used with Oracle Utilities Customer To Meter.
