Creating Object Storage Locations
Note: Object Storage Locations are used with cloud services only.
When using Smart Grid Gateway adapters with cloud services, you need to create one or more buckets in Oracle Object Storage where payload files will be sent for processing. Refer to the Oracle Utilities Cloud Services Object Storage Setup Guide and the Oracle Cloud Infrastructure documentation for more information about creating buckets in Oracle Object Storage.
After creating the buckets in Oracle Object Storage, make a note of the following, as this information is needed in later configuration steps:
  • Namespace
  • User Oracle Cloud ID (User OCID)
  • Tenancy Oracle Cloud ID (Tenancy OCID)
  • Compartment Oracle Cloud ID (Compartment OCID)
Suggested Buckets for Payload Processing
This section outlined suggested sets of Object Storage buckets for each of the Smart Grid Gateway adapters.
General Guidelines
As a general rule, each adapter should have separate buckets for each of the following:
  • Usage payloads
  • Usage archive
  • Usage errors
  • Device Event payloads
  • Device Event archive
  • Device Event errors
If an adapter uses payloads in more than one format (such as in CSV and XML formats), you should also consider creating separate buckets for each file format type.
Note: If possible, archive buckets should be created in an “Archive” storage tier.
Adapter Development Kit
The table below lists suggested Object Storage buckets for the Adapter Development Kit:
Bucket Name
Storage Tier
Smart Grid Gateway Description
adk-csv
Standard
SGG ADK Adapter - CSV input
adk-csv-arch
Archive
SGG ADK Adapter - CSV archive
adk-csv-error
Standard
SGG ADK Adapter - CSV errors
adk-seeder
Standard
SGG ADK Adapter - IMD Seeder input
adk-seeder-arch
Archive
SGG ADK Adapter - IMD Seeder archive
adk-seeder-error
Standard
SGG ADK Adapter - IMD Seeder errors
adk-xml
Standard
SGG ADK Adapter - XML input
adk-xml-arch
Archive
SGG ADK Adapter - XML archive
adk-xml-error
Standard
SGG ADK Adapter - XML errors
Adapter for Itron OpenWay
The table below lists suggested Object Storage buckets for the Adapter for Itron OpenWay:
Bucket Name
Storage Tier
itronexception
Standard
SGG Itron OW Adapter - event input
itronexception-arch
Archive
SGG Itron OW Adapter - event archive
itronexception-error
Standard
SGG Itron OW Adapter - event errors
itronxml
Standard
SGG Itron OW Adapter - XML input
itronxml-arch
Archive
SGG Itron OW Adapter - XML archive
itronxml-error
Standard
SGG Itron OW Adapter - XML errors
MV90 Adapter for Itron
The table below lists suggested Object Storage buckets for the MV90 Adapter for Itron
Bucket Name
Storage Tier
mv90-usage
Standard
SGG MV90 Adapter - usage input
mv90-usage-arch
Archive
SGG MV90 Adapter - usage archive
mv90-usage-error
Standard
SGG MV90 Adapter - usage errors
Adapter for Landis+Gyr
The table below lists suggested Object Storage buckets for the Adapter for Landis+Gyr:
Bucket Name
Storage Tier
lg-cim-event
Standard
SGG Landis+Gyr Adapter - CIM input
lg-cim-event-arch
Archive
SGG Landis+Gyr Adapter - CIM archive
lg-cim-event-error
Standard
SGG Landis+Gyr Adapter - CIM errors
lg-event
Standard
SGG Landis+Gyr Adapter - event input
lg-event-arch
Archive
SGG Landis+Gyr Adapter - events archive
lg-event-error
Standard
SGG Landis+Gyr Adapter - event errors
lg-usage
Standard
SGG Landis+Gyr Adapter - usage input
lg-usage-arch
Archive
SGG Landis+Gyr Adapter - usage archive
lg-usage-error
Standard
SGG Landis+Gyr Adapter - usage errors
Adapter for Sensus
The table below lists suggested Object Storage buckets for the Adapter for Sensus:
Bucket Name
Storage Tier
sensus-event
Standard
SGG Sensus Adapter - event input
sensus-event-arch
Archive
SGG Sensus Adapter - events archive
sensus-event-error
Standard
SGG Sensus Adapter - event errors
sensus-usage
Standard
SGG Sensus Adapter - usage input
sensus-usage-arch
Archive
SGG Sensus Adapter - usage archive
sensus-usage-error
Standard
SGG Sensus Adapter - usage errors
Adapter for Silver Spring Networks
The table below lists suggested Object Storage buckets for the Adapter for Silver Spring Networks:
Bucket Name
Storage Tier
ssn-csv
Standard
SGG SSN Adapter - CSV input
ssn-csv-arch
Archive
SGG SSN Adapter - CSV archive
ssn-csv-error
Standard
SGG SSN Adapter - CSV errors
ssn-ssnxml
Standard
SGG SSN Adapter - XML input
ssn-ssnxml-arch
Archive
SGG SSN Adapter - XML archive
ssn-ssnxml-error
Standard
SGG SSN Adapter - XML errors
