Sensus Web Service Authentication
MultiSpeak 4.1 Release
Inbound Requests
Include “/multispeak41” prior to the inbound web service name in the URL to signal the application that it should locate credentials in the MultiSpeakMsgHeader SOAP Header element.
Ex: https://144.25.13.161:8086/tnt22a/test03/ccs/soap/api/iws/multispeak41/D6-CB_Server
Outbound Requests
On the Context tab of the Message Sender portal, add a Sender Security Type row with a value of “MS_V41R” (as shown in the following screen capture). The values of the HTTP Login User and HTTP Login Password will be added as attributes of MultiSpeakMsgHeader in the outgoing SOAP header.
![Screen capture showing the Sender Security Type parameter set to "MS_V41R" on the Context tab of the Message Sender portal.](../images/SGG_Native_Authentication_Sensus-Message_Sender.jpg)
