Groovy Imports Steps
Note: Server based scripts only. This step type is not applicable to BPA scripts.
Groovy Imports step types provide a free format text area where you list the Groovy classes to be imported for use by the code in Groovy Member steps within the script.
Enter a description of the imports step in the Text field. Click the adjacent icon to open a window providing more space for entering text.
Enter the list of classes to import in the Edit Data Text field using the syntax import 'class'; where 'class' is the fully qualified package name of the Groovy class. Click the adjacent icon to open a window providing more space for editing the text.
When saving a script, if the system has been configured accordingly, when the system detects references to a Groovy class that is not explicitly listed in this step, the system warns the user and adds an explicit import for that class. (If no Groovy Import step type exists for the script, one will be added.) Users should review the imported class to ensure it is the expected class, in the case of multiple classes with a similar name.
Note: For security, the classes that may be imported are restricted to those allowed by the Framework. The warning and automatic update to the script is controlled by a property setting. Refer to the topic Using Groovy Within Scripts for more information.
