Press A Button Steps
BPA scripts only. This step type is
only applicable to BPA scripts.
CAUTION: Guiding scripts that interact with the user using the
script area are limited to surf over fixed pages only and are considered legacy functionality.
This technique is not supported on top of portal pages and is planned to be deprecated in a
future release.
Press a button steps cause a button or link text to be ‘pressed’ in the object display area, the application toolbar or the page title area. For example, you could use this type of step to add a new row to a person's characteristic (and then you could use a Move Data step to populate the newly added row with a given char type and value). The following additional fields are required for Press a button steps:
Button Name is the name of the button to be pressed. This button must reside on the currently displayed tab page (or in the application toolbar or page actions toolbar). Refer to How To Find The Name Of A Button for more information.
