Operations Mobile Application Installation and Deployment Guide
Audience
Related Documents
Conventions
Installation and Deployment Overview
Server Installation Overview
Client Development Installation Overview
Client Configuration Overview
Client Deployment Overview
Supported Platforms & Hardware Requirements
Client Hardware Requirements
Server Hardware Requirements
Application Server
Development Hardware Requirements
Prerequisite Software
Mobile Gateway Server Installation
Mobile Gateway Architecture
Deploy the Mobile Gateway
Configuring WebLogic to Handle HTTP Basic Challenges Correctly
Configuring the Default Control Zone and Crew Defaults
NMS Server Configuration
GeoJSON Map Generation
Overview
Directory Location
Build Processes
GeoJSON Configuration File
GeoJSON Map Deployment
GeoJSON Offline Landbase Maps
Overview
Mobile User Validation
Permissions and Permission Sets
Predefined Users
Creating Users Using a Key
Using LDAP/AD User Validation
Mobile Applications Validation
Server Based Documents
Overview
Document Locations
Document Configuration
Configuring OMA Object Attribute Viewer
Overview
Configuration
Configuring OMA For Schematic Maps
Overview
Configuration
Configuring OMA Search Options
Overview
Configuration
Identity Cloud Service Provider
Overview
Identity Cloud Service – Setup
URL with IDCS Login Script
NMS WebLogic Managed Server – IDCS Integration Provider
Configure the OMA Client
Client Development Setup
Install Software
Install Prerequisite Software
Install Operations Mobile App SDK
Build Operations Mobile Application
Testing
Client PWA Installation Instructions
Client PWA Update Instructions
Client PWA Uninstall Instructions
Windows - Edge
Removing a Chrome OMA PWA on Windows and Linux
Option 1: Windows and Linux
Option 2: Windows and Linux
Option 3: Windows
Android
iOS
OMA Client Configuration
Migrating Map Configuration from Previous OMA Versions
Third Party Application Integration with the OMA Client
Third Party Application Integration with localhost HTTP Bridge (Windows 10)
Deep Links Using an OMA PWA Wrapper
mapfocus
open
mainpage
crewstatus
getinfo
Client Deployment
Server Application Install Instructions
Server Application Update Instructions
OMA Native PWA Wrappers
Building and Deploying the OMA PWA Wrapper for Android
Building and Deploying the OMA PWA Wrapper for iOS
How to Issue a Local Notification from OMA When Using the PWA Wrapper
Operations Mobile Application Setup on OPAL
Operations Mobile Application Project Setup
Restricted Use and User License Terms
Mobile Archive Restricted Use
Network Management System Operations Mobile Application Installation and Deployment Guide
