Understanding Event Details
Event Details is used is used to enter and track information about events. It displays different types of event information in tabs. Multiple events may be displayed with their own tab.
To open Event Details, double-click the desired event's row in the Work Agenda. You can also select an event and click the Event Details toolbar button or select Event Details... from the Work Agenda Actions or the row's context menu.
The Event Details window is comprised of:
Menus and Toolbar
This section describes the menu and toolbar options. In the tables below, each menu item is listed along with sub‑menu options, if available, and the default toolbar icon, if applicable; menu items without a default toolbar icon are indicated with a double dash (--) in the toolbar icon cell.
