User Menu
The User Menu provides submenus with options to change the appearance and functionality of user interface elements and log out of Web Callbacks.
User Interface Settings Menu
Menu Option
Description
Theme Selection Radio Buttons
• Dark Theme
• Light Theme
Theme selection allows you to choose whether the Web Callbacks uses a Dark Theme or a Light Theme.
• The Dark Theme is generally better for low-lit conditions.
• The Light Theme is generally better for well-lit conditions.
Capitalize Field Labels
If selected, field labels will be displayed in All Caps (for example, NAME). If not selected, field labels will be displayed in title case (for example, Name).
Toggle Accessible Mode
Changes settings to enable use with screen readers. Note: There are prerequisites to enabling accessible mode. Please see Appendix A‑Accessibility Features for information on enabling Accessible mode.
Show Messages at Mouse Location
Sets the system to display popup confirmation and warning dialog boxes at your mouse pointer position.
Smaller Font
Decreases the font size in text and icons. Repeat to further decrease the font size.
Bigger Font
Increases the font size in text and icons. Repeat to further increase the font size.
Reset Font
The application will reset the text and icons to use their default font size.
Darken Watermarks
Make the watermarks more opaque.
Lighten Watermarks
Make the watermarks more transparent.
Show Watermarks
Allows you to toggle watermarks on or off.
Table Settings Menu
The Table Settings submenu allows you to configure how tables will appear.
Menu Option
Description
Alternate Row Coloring
When selected, displays data table rows in alternating colors.
Capitalize Column Headings
Allows you to select whether column labels should be displayed in all capital letters (for example, STATUS) or in title case (for example, Status)
Table Color Formatting Mode
Determines whether and how tables will display background coloring.
Options
• None: Tables will not contain color indicators for statuses.
• Cells: Table cells will contain background colors based on the cell statuses.
• Row: All cells in a table row will have the background color.
Table Font Formatting Mode
Determines whether and how tables will display font formatting.
Options
• None: Conditional formatting related to font formatting are never shown.
• Cells: Conditional formatting related to font formatting are applied only to the cells they were configured for.
• Row: Conditional formatting related to font formatting are applied across the whole row. Where more than one formatting rule is applied, the highest priority rule is displayed.
Manage Preferences Menu
Menu Option
Description
Save Preferences
Saves your preferences to the database so your settings are available wherever you log in. See “Saving and Restoring Workspace Preferences” for more information.
Note: Theme selection is saved to your user settings on the workstation since they are more likely influenced by the light in a location. See “Understanding the User Interface Settings Menu” for information.
Restore Preferences
Opens a dialog box that allows you to select the preferences to restore. See “Saving and Restoring Workspace Preferences”.
Manage Site-wide Settings
Options
• Update Site-wide Preferences: Users who have Administration permissions (having access to the Configuration Assistant) may log in as a different user type, configure, and save the default preferences for all users of the log in type.
• Restore Site-wide Preferences: Users who have Administration permissions (having access to the Configuration Assistant) may restore the default preferences for the logged in user type to the original configuration. See “Saving and Restoring Workspace Preferences” for more information.
User Logout: Logs you out of the system and shuts down the client.
