Tab | Description |
Request | Use this to view and enter information about the user who requested the switching sheet, including phone number and contact, the sheet's owner, charge number, start and finish dates, feeder and voltage information. See “Completing the Request Tab”. |
Steps | Use this to view, add, and edit switching steps. See “Adding and Editing Steps”. |
Impacted Customers | Use this to view, print, email, and maintain the list of impacted customers. See “Viewing Impacted Customers”. |
Overlaps | Use this view to identify overlaps that the sheet may have with other sheets in the system. The search criteria can include date/time, control zone, and affected devices. See “Checking for Overlaps”. |
External Documents | Use this to attach external documents to the switching sheet. See “Adding External Documents to a Switching Sheet”. |
View Areas | Use this to save and reload viewing areas from a Viewer window. See “Saving and Loading View Areas”. |
Safety Documents | Use this to view, load, and delete safety documents that have been defined for this sheet. See “Working with Safety Documents”. |
Tracking/Audit Log | Use this to view audit log entries associated with this sheet. See “Viewing the Audit Log”. You can also use this to view the current sheet state or transition to another state. See “Changing the Switching Sheet State”. |
