Asset Details Mapping
The product can be configured to support various mapping approaches between GIS features and assets. The following are high level guidelines to consider when designing such mapping:
  • Analyze your GIS feature classes
    • Determine which feature classes should be synchronized.
    • Determine if subsets of a synchronized feature class should be skipped.
    • Determine which GIS fields should be synchronized in each direction.
    • Determine if value mapping is needed for some GIS values.
  • Extend the base asset location business object if custom GIS location details need to be supported.
  • Use asset attributes when possible, to store GIS asset related details
  • Define corresponding non-tracked Asset Types and Asset Location Types.
  • For each synchronized feature class define the following:
    • Custom value mapping extendable lookups for specific GIS field values that may need to be mapped to different values.
    • A GIS to WAM extendable lookup.
    • A WAM to GIS extendable lookup if some asset details should be continuously synchronized back to the GIS system.
