Configuring Outbound Messages in External System
External System for Work Location and Asset Outbound Sync
Configure an external system record for the GIS system your company sends messages to. Refer to External System for more information.
Provide an entry for each of the outbound message types associated with the GIS Integration web service category following these guidelines:
Field Value
Outbound Message Type The provided outbound message type
Processing Method Real-time
Message Sender The corresponding message sender for this type of message
Date/Time Format XSD
JSON Conversion Method REST: XSL Transformation
Message XSL SOAP: W1-CommonGISRequestForSOAP.xslREST: W1-CommonGISRequestForREST.xsl
Response XSL
SOAP: W1-CommonGISResponseForSOAP.xsl
REST: W1- CommonGISResponseForREST.xsl (for WAM if File System is used for XSL files)
REST: W1-CommonGISRespForREST.xsl (for WACS if Managed Content is used for XSL files)
External System for Asset Inbound Sync and Token Generation
Field Value
JSON Conversion Method XSL Transformation
Response XSL W1–GISAssetInbound.xsl
