Sending Customer Settlement Transaction Requests
Customer settlement transactions are created upon requests from a customer information system. Customer settlement transaction requests are sent in a file which is processed by a batch process which creates the individual customer settlement transactions. Customer settlement transaction requests include the metered service, the start and end date for the requested time period, and the type of request.
See About Customer Settlement Transactions for more information.
Uploading Customer Settlement Transaction Requests
Customer settlement requests are uploaded using the Customer Settlement Transaction Upload (X1-CSTUP) batch process. This batch process uploads data from a .tab-delimited file. For each data row in the file, this process creates a Customer Settlement Transaction record.
This batch processes use the following parameters:
File Name: The name of the file to upload. File names can use wildcards (Required)
Flat Path: The file location where the upload file is located. This can be a file location on a local server or a location in Object Storage. See Referencing URIs in the Framework Administrative User Guide for more information. (Required)
Processed File Extension: The text appended to the file name after the file has been processed. Default is "PROCESSED".
Error On No Files Found: Indicates whether or not an error is issued if no files are found matching the given name in the given path. Valid values are "true" (default) and "false".
Use the Batch Control portal to learn more about these and other parameters used by these batch process.
Customer Settlement Request Upload File Format
Customer settlement request upload files use the following tab-separated values format:
Field Name |
Optional/Required |
Notes |
External Settlement Request ID |
Required |
An id for the customer settlement request from the CIS application. |
External Metered Service ID |
Required |
The external id of the metered service for which the Customer Settlement will be created. |
Start Date |
Required |
The date on which the customer settlement period starts. This assumes a start time at the start of the day. |
End Date |
Required |
The date on which the customer settlement period ends. This assumes a start time at the end of the day. |
Customer Settlement Request Type |
Required |
A flag that indicates the type of customer settlement request. Valid values are values for the Event Settlement Request Type (EVT_SETT_REQ_TYPE_FLG) lookup, and include:
Sample Record
Below is a sample file:
Tmp5 MBFEXT0605_1 2023-04-06 2023-04-07 D1FL
