Understanding Event Settlement Calculation Rules
Event settlement calculation rules are rules that perform event settlement calculations and create event settlement transactions, which represent credits that will be applied to a customer's bill based on participation in an individual event (see About Event Settlement Transactions). Event settlement calculation rules are created for a specific event settlement calculation group. For example, if you were configuring two event settlement calculation groups and both included a specific event settlement calculation rule, you would need to create two instances of the event settlement calculation rule, one for each group.
The base package includes the following program calculation rule business objects:
Event Settlement Calculation Rule |
Description |
Event Settlement Calculation Rule (X1-EventSettlementCalcRule) |
This rule is used to calculate settlement results for events. |
System Data
Event calculation rules are based on the system data:
Data Type |
Description |
Maintenance Object |
Usage Rule (D1-USGRULE) |
Business Object(s) |
